Knowledge Base Article
Why does the GTS HDMI FPGA IP, GTS DisplayPort PHY FPGA IP and GTS JESD204C IP Design Example fail to compile during synthesis stage when the Relative Offset has been set to a nonzero value in Dual Simplex Assignment Editor?
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 24.2, the Relative Offset for the GTS HDMI FPGA IP, GTS DisplayPort PHY IP, and GTS JESD204C IP with Dual Simplex configurations in the Agilex™ 5 FPGA devices is limited to a value of "0".
The following error will be seen if a non-zero relative offset value is used.
Error(13076): The node "u_DS_GROUP_0|hdmi_tx_inst0__hdmi_tx__u_tx__direct_phy_tx__g1_period_n_period_sys_lsqb_0_rsqb__period_n_channel_superset_ip_inst__n_channel_superset_top_wrapper__hal_top_wrapper_inst__hal_top_ip__one_lane_inst_0__one_lane_hal_top_p0__phy_hal_top_inst__phy_hal_top__phy_hal_coreip_inst__ch4_phy_inst__x_std_sm_flux_ingress_0" has multiple drivers.
  Error(20073): "non-tri-state driver "u_DS_GROUP_0|hdmi_tx_inst0__hdmi_tx__u_tx__direct_phy_tx__g1_period_n_period_sys_lsqb_0_rsqb__period_n_channel_superset_ip_inst__n_channel_superset_top_wrapper__hal_top_wrapper_inst__hal_top_ip__one_lane_inst_0__one_lane_hal_top_p0__phy_hal_top_inst__phy_hal_top__phy_hal_coreip_inst__ch4_phy_inst__x_std_sm_flux_ingress_0"" is one of the multiple drivers.
  Error(20073): "non-tri-state driver "u_DS_GROUP_0|dstool__tennm_sm_flux_ingress_ch1_0"" is one of the multiple drivers.
  Error(20073): "non-tri-state driver "u_DS_GROUP_0|dstool__tennm_sm_flux_ingress_ch2_0"" is one of the multiple drivers.
  Error(20073): "non-tri-state driver "u_DS_GROUP_0|dstool__tennm_sm_flux_ingress_ch3_0"" is one of the multiple drivers.
Resolution
There is no workaround for this problem.
This problem is fixed beginning with version 24.3.1 of the Quartus® Prime Pro Edition Software.
Updated 11 months ago
Version 3.0
