Knowledge Base Article
Why does the GTS HDMI FPGA IP Design Example fail on hardware?
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 24.3.1, the GTS HDMI FPGA IP Design Example fails to link after programming. This is due to the Input Reference Clock Buffer Protection enablement; the clock buffers are turned off before device configuration starts and never turned back on even when the reference clock becomes available.
Resolution
A patch is available to fix this problem for the Quartus® Prime Pro Edition Software version 24.3.1.
Download and install Patch 1.02fw from the following links:
- quartus-24.3.1-1.02fw-windows.exe
- quartus-24.3.1-1.02fw-linux.run
- Readme for version 24.3.1 Patch 1.02fw (.txt)
The problem has been fixed starting with Quartus® Prime Pro Edition software version 25.1.
Updated 4 months ago
Version 7.0No CommentsBe the first to comment
