Knowledge Base Article
Why does the Generic Serial Flash Interface Intel® FPGA IP hang if the avl_csr and avl_mem are accessed at the same time?
Description
This problem will be seen in the Intel® Quartus® Prime Software when accessing the Avalon® Memory-Mapped Agent Interface for CSR and Avalon® Memory-Mapped Agent Interface for Memory Access ports at the same time in Generic Serial Flash Interface Intel® FPGA IP.
Both ports must be accessed at different times.
Resolution
There is no workaround. You are advised to access the two ports separately.
For more information, refer to the Generic Serial Flash Interface Intel® FPGA IP User Guide - Signals.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
