Knowledge Base Article
Why does the FPGA Power and Thermal Calculator underestimate the power consumption of RAM resources when importing a .qptc file?
Description
Due to a problem in FPGA Power and Thermal Calculator (PTC), the power estimation in the RAM tab might not be accurate when ROM mode is being used in the design when importing a .qptc file generated from Quartus® Prime Pro Edition Software version 23.1 and later into the PTC.
Resolution
For more accurate power estimation, either refer to power estimation reported in Quartus® Power Analyzer or ensure that the Read Enable % is set accordingly for the ROM instances on the RAM page once the .qptc file is imported.
This problem will be fixed in FPGA Power and Thermal Calculator version 24.1.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
