Knowledge Base Article
Why does the F-Tile System PLL fail to lock when the reference clock is active only after configuration?
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 26.1 and earlier, you might observe the F-Tile System PLL lock failure when your design has both below requirements:
  • More than one System PLL are enabled in one F-Tile, e.g. syspll0 and syspll1
  • One System PLL reference clock source will only be active after the other System PLL is locked. E.g. syspll0 refclk is active only after syspll1 is locked.
Failure Symptom:
The later System PLL will never lock. E.g syspll0 refclk is active only after syspll1 is locked, then syspll0 could never lock.
Background:
When a System PLL reference clock source is not active at configuration, then all System PLL reference clock must unselect parameter
And the F-Tile Reference and System PLL Clocks FPGA IP will expose below control signals for each System PLL:
  • refclock_ready[n]
  • en_refclk_fgt_i
Expected behavior:
For each System PLL #n, after its reference clock source #i is active, then we can drive refclock_ready[n] and en_refclk_fgt_i to get System PLL #n locked independently from other System PLL.
Root Cause:
A SSM (Secure Socket Manager) FW bug causes the control signals of the 3 System PLLs can not work independently.
Resolution
There is no workaround available.
This problem is scheduled to be fixed in a future release of the Quartus Prime Pro Edition software.
Updated 4 months ago
Version 3.0
