Knowledge Base Article
Why does the F-tile Serial Lite IV IP design with PAM4 modulation fail to achieve link up during simulation?
Description
Due to a problem in the Quartus® Prime Pro Edition software 24.2 and earlier versions, you might observe the F-tile Serial Lite IV Intel FPGA IP design with PAM4 modulation fail to get the rx_link_up asserted in simulation. This is because rx_cdr_lock is not asserted, which results in rx_pcs_ready not being asserted. This failure is caused by misinterpreting the AIB master and slave, introducing a deskew error in serial data in the soft reset controller.
Resolution
There is no workaround available.
  • This problem only exists in simulation and does not impact the hardware testing results.
  • This problem might disappear when you re-run the simulation. This is because the simulator might support random seed generation, and some seeds will not encounter this failure.
This problem is fixed beginning with the Quartus® Prime Pro Edition Software version 24.3.1.
Updated 1 month ago
Version 2.0
