Knowledge Base Article
Why does the F-Tile JESD204C Altera® IP have the j204c_tx/rx_rst_ack_n signals not deassert properly even when tx/rx_rst_n signal has been deasserted and adhered to the F-Tile JESD204C Altera® IP TX/RX Reset Sequence in simulation?
Description
It is observed that the j204c_tx/rx_rst_ack_n acknowledgment reset signals are not deasserting (low -> high) and remain asserted at logic level ‘0’.
This behavior is observed even after the user has deasserted the reset signals j204c_tx/rx_rst_n and j204c_tx/rx_rst_avs_n by following the F-Tile JESD204C Altera® IP TX1/RX2 Reset Sequence.
There is a Soft Reset Controller (SRC), an internal soft IP module that the F-Tile JESD204C Altera® IP depends on to synchronize the resets across individual lanes in the transceiver. The j204c_tx/rx_rst_ack_n signals depend on this SRC module to determine their proper state.
In Quartus® Prime Pro Edition Software version 24.1, FastSIM mode was introduced, speeding up simulation times. As a result, one of the optimizations performed is to speed up the SRC initialization. Due to this, the F-Tile JESD204C Altera® IP did not initialize some internal signals properly in time, as the j204c_tx_avs_clk was provided late. The SRC initialization occurred before the j204c_tx_avs_clk was first toggled. As a result, the j204c_tx/rx_rst_ack_n signal is improperly initialized, leading to improper behavior.
Prior to Quartus® Prime Pro Edition Software version 24.1, this issue was not observed because FastSIM was not enabled for the SRC module, and the SRC initialization happens after the j204c_tx_avs_clk starts toggling. Hence, the j204c_tx/rx_rst_ack_n signals de-asserted properly after exiting from reset.
This issue affects simulation only and is not observed in hardware.
Reference:
[1] 5.1.1. F-Tile JESD204C TX Reset Sequence
[2] 5.1.2. F-Tile JESD204C RX Reset Sequence
Resolution
A patch has been released to address this issue for the Quartus® Prime Pro Edition Software version 24.2. This problem is also fixed starting with the Quartus® Prime Pro Edition Software version 24.3.
For users who are unable to migrate to the Quartus® Prime Pro Edition Software version 24.2, we recommend the following workaround:
Initialize the F-Tile JESD204C Altera® IP in a reset state and ensure that the j204c_tx_avs_clk clock signal is locked. Refer to the following code sample:
reconfig_xcvr_reset = '1;
j204c_tx_avs_rst_n = '0;
j204c_rx_avs_rst_n = '0;
j204c_tx_rst_n = '0;
j204c_rx_rst_n = '0;
Note that the reconfig_xcvr_reset signal is active high while the other reset signals are active low.
Once the j204c_tx_avs_clk is locked, users can follow the F-Tile JESD204C TX/RX Reset Sequence to exit out of reset. Ensure that the j204c_tx/rx_rst_ack_n = 0 before exiting out of reset. For more information about this sequence, refer to [1].
To work around this problem in the Quartus® Prime Pro Edition Software version 24.2, install the patch below.
This problem is fixed beginning with the Quartus® Prime Pro Edition Software version 24.3.
Related Articles
