Knowledge Base Article
Why does the F-Tile HDMI IP Design Example in AXIS-VVP Without Frame Buffer mode fail to output at certain resolutions (4k60 and above) on the Agilex™ 7 FPGA?
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 25.1, the F-Tile HDMI IP Design Example in AXIS-VVP Without Frame Buffer mode will fail to output certain resolutions (for example, 4k60 and above) for the Agilex™ 7 FPGA devices.
Resolution
To work around this problem, use the F-Tile HDMI IP Design Example in AXIS-VVP with Frame Buffer TMDS mode when targeting 4k60 resolution and above.
This problem is scheduled to be fixed in the future release of the Quartus® Prime Pro Edition Software.
Updated 3 months ago
Version 2.0
