Knowledge Base Article
Why does the F-Tile HDMI IP Design Example fail to generate when using AXI4-streaming with TMDS mode?
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 24.2, the following error will appear when generating the F-Tile HDMI IP Design Example when using AXI4-streaming with TMDS mode.
Error Message :
Info: hdmi_0: Generating reset_release IP
Info: hdmi_0: Creating software
Error: invalid command name "}"
while executing
(procedure "doGeneration" line 50)
invoked from within
"doGeneration"
(procedure "altera_terp" line 43)
invoked from within
"altera_terp $terp_contents terp_params"
Resolution
No workaround to this problem exists in version 24.2 of the Quartus® Prime Pro Edition Software.
This problem was fixed in the Quartus® Prime Pro Edition Software version 24.3.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
