Knowledge Base Article
Why does the F-Tile HDMI Intel® FPGA IP Design Example with Fixed Rate Link (FRL) take so long to compile on Windows?
Description
Due to a SDC problem in the F-Tile HDMI Intel® FPGA IP Design Example with Fixed Rate Link (FRL) an SDC constraint intended for generating reconfiguration profiles, causes the fitter stage to take a longer time during compilation.
Resolution
A patch is available to fix this problem for the Intel® Quartus® Prime Pro Edition Software version 22.3.
Download and install Patch 0.45 from the following links:
A patch is available to fix this problem for the Intel® Quartus® Prime Pro Edition Software version 22.4.
Download and install Patch 0.28 from the following links:
This problem has been fixed starting in version 23.1 of the Intel® Quartus® Prime Pro Edition Software.
Updated 8 months ago
Version 3.0
