Knowledge Base Article
Why does the F-Tile HDMI FPGA IP Design Example fail to work on hardware in the Quartus® Prime Pro Edition Software version 23.2?
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 23.2, the default setting of rx_term_mode_select in the F-Tile PMA/FEC Direct PHY FPGA IP changes from RX_TERM_MODE_SELECT_GROUNDED to RX_TERM_MODE_SELECT_FLOATING.
The F-Tile HDMI FPGA IP Design Example does not set the required rx_ac_couple_enable Quartus Settings File (QSF) constraint in the Quartus® Prime Pro Edition Software version 23.2, which causes the design example to fail in hardware for the Agilex™ 7 FPGA I-Series Transceiver-SoC Development Kit(4x F-Tile).
Resolution
To work around this problem:
Set the required rx_ac_couple_enable constraint to ENABLE in the QSF file:
set_instance_assignment -name HSSI_PARAMETER "rx_ac_couple_enable=ENABLE" -to fmc_rx_p[0] -entity agx_hdmi21_frl_demo
set_instance_assignment -name HSSI_PARAMETER "rx_ac_couple_enable=ENABLE" -to fmc_rx_p[1] -entity agx_hdmi21_frl_demo
set_instance_assignment -name HSSI_PARAMETER "rx_ac_couple_enable=ENABLE" -to fmc_rx_p[2] -entity agx_hdmi21_frl_demo
set_instance_assignment -name HSSI_PARAMETER "rx_ac_couple_enable=ENABLE" -to fmc_rx_p[3] -entity agx_hdmi21_frl_demo
This problem is fixed beginning with the Quartus® Prime Pro Edition Software version 23.3.
Updated 2 months ago
Version 2.0
