Knowledge Base Article
Why does the F-Tile FHT transceiver design fail in the “Support Logic Generation” phase when the “Select FHT Lane PLL refclk source” parameter is set to "REF_TO_GND" as default?
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 23.2, you might see failure in the “Support Logic Generation” phase when the Select FHT Lane PLL refclk source parameter is set to REF_TO_GND as default.
Resolution
To work around this problem in the Quartus® Prime Pro Edition Software version 23.2, select FHT Lane PLL refclk source to either PLL_100_MHZ or PLL_156_MHZ.
Updated 2 months ago
Version 3.0
