Knowledge Base Article
Why does the F-Tile Ethernet Multirate FPGA IP start transmitting invalid packets when the “i_p<n>_tx_rst_n” or “o_p<n>_rst_n” signals are deasserted?
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 23.4, the F-Tile Ethernet Multirate FPGA IP will transmit invalid packets when the “i_p<n>_tx_rst_n” or “o_p<n>_rst_n” signals are deasserted If the “Enable IEEE 1588 PTP” parameter is set and the “Link fault generation” parameter option is set to “Bidirectional”.
These invalid packets are not driven by the client interface.
The packets are typically 64 bytes long and only contain zeroes in all of the fields.
Resolution
There is no work around to this problem.
This problem has been fixed starting in version 24.3 of the Quartus® Prime Pro Edition Software.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
