Knowledge Base Article
Why does the F-Tile Avalon® Streaming Intel® FPGA IP for PCI Express Design Example generation fail when using the Intel® Quartus® Prime Pro Edition Software version 22.1
Description
The error "Error: can't read "rp_generated_name": no such variable" will be observed when generating the F-Tile Avalon® Streaming Intel® FPGA IP for PCI Express Design Example using the Intel® Quartus® Prime Pro Edition Software version 22.1.
The error is caused by attempting to generate the design example with Example Design Files "Synthesis" option enabled, but the "Simulation" option is not enabled.
Resolution
To work around this problem, ensure that both Simulation and Synthesis options are enabled before clicking the "Generate Example Design" button.
This problem has been fixed starting in version 22.3 of the Intel® Quartus® Prime Pro Edition Software.
Updated 2 months ago
Version 2.0
