Knowledge Base Article
Why does the example design for Stratix® 10 10GBASE-KR PHY IP generated using the Quartus® Prime Pro Edition software version 24.3 and run in Questa*-Intel® FPGA or Starter Edition fail during simulation?
Description
Due to a problem in the Stratix® 10 10GBASE-KR PHY IP example design generated using the Quartus® Prime Pro Edition software version 24.3, the simulation fails for the  Questa*-Intel® FPGA or Starter Edition simulators.
Resolution
To work around this problem, make the following changes in the testbench.v, testbench related file.
1) Add the following line,
parameter SIM_TIMEOUT = 64'd5000000000;
2) At Line 225 (before the change#1),
for (cycle = 1; cycle <= 1; cycle = cycle + 1) begin
Change to:
for (cycle = 1; cycle <= 6; cycle = cycle + 1) begin
3) Lines 323 to 328 (before the change#1)
///// 2.0ms timeout
initial begin
#2_000_000_000; //ms
$display ("Test did not finish. Timing out at 2ms");
$finish();
end
Change to:
///// 5.0ms timeout
initial begin
#SIM_TIMEOUT ;
$display ("Test did not finish. Timing out at 5ms");
$finish();
end
This issue will be fixed in a future version of the Quartus® Prime Pro Edition Design Software.
Updated 3 months ago
Version 2.0
