Knowledge Base Article
Why does the DisplayPort Intel® Stratix® 10 FPGA IP Design Example fail RX link training at High Bit Rate 3 (HBR3)?
Description
Due to a problem in the DisplayPort Intel® Stratix® 10 FPGA IP Design Example generated with the Intel® Quartus® Prime Design Software versions 20.3 and earlier, you may observe RX link training failure at HBR3 and the link down trains to HBR2.
Resolution
To workaround this problem in the Intel® Quartus® Prime Pro Edition Software version 20.3 and earlier, follow the steps:
1. Replace ./rtl/rx_phy/rx_phy_top.v with rx_phy_top.v
2. Replace ./rtl/tx_phy/tx_phy_top.v with tx_phy_top.v
3. Replace ./rtl/bitec_reconfig_alt_s10.v with intel_reconfig_alt_s10.v
This problem is fixed in the Intel® Quartus® Prime Pro Edition Software version 20.4 and later.
Updated 8 months ago
Version 3.0No CommentsBe the first to comment
