Knowledge Base Article
Why does the CSR access data width of R-Tile Intel® FPGA IP for Compute Express Link* (CXL*) Design Example mismatch the function in the software driver?
Description
Due to a problem in Intel® Quartus® Prime Pro Edition Software version 23.2 and later, the CSR access data width is changed from 32bit to 64bit in R-Tile Intel® FPGA IP for Compute Express Link* (CXL*) Type2/3 Design Example; this causes a mismatch between software driver function and user CSR logic design.
Resolution
This problem is not planned to be fixed in future releases of the Intel® Quartus® Prime Edition Software.
To work around this problem, refer to the following code example:
1. Open /hardware_test_design/common/ex_default_csr/ex_default_csr_avmm_slave.sv
2. Implement the CSR with a 64-bit data width rather than the standard 32-bit data width.
//64bit data width
always @(posedge clk )
if (!reset_n) begin
ats_stu <= 5'b0;
ats_en <= 1'b0;
ptm_eg <= 8'b0;
ptm_rs <= 1'b0;
ptm_en <= 1'b0;
end else if (write && config_access)begin
case(address[20:0])
21'h00E00 : begin
ats_stu <= writedata[60:56];
ats_en <= writedata[63];
end
21'h00E18 : begin
ptm_eg <= writedata[15:8];
ptm_rs <= writedata[1];
ptm_en <= writedata[0];
end
default ;
endcase
end
//Read logic
if (!reset_n) begin
cfg_readdata <= 64'h0;
end else if(read&&config_access)begin
case(address[20:0])
21'h00E00 : cfg_readdata <= {{ats_en,10'b0,ats_stu,16'h0020},EX_CAP_HEADER_ATS };
// 21'h00E04 : cfg_readdata <= {{ats_en,10'b0,ats_stu,16'h0020},32'b0} ;
21'h00E10 : cfg_readdata <= {EX_CAP_HEADER_PTM_CAP,EX_CAP_HEADER_PTM};
// 21'h00E14 : cfg_readdata <= {EX_CAP_HEADER_PTM_CAP,32'b0};
21'h00E18 : cfg_readdata <= {32'b0 ,{16'h0,ptm_eg,6'h0,1'b0,ptm_en}};
default : cfg_readdata <= {32'b0 ,32'hffff_ffff };
endcase
end else begin
end
