Knowledge Base Article
Why does the c5gt_pro_goldentop.v file in the Cyclone® V GT installation kit include ground connections for the hard memory controller?
Description
You may see a discrepancy between the following two files in the Cyclone® V GT installation kit:
- c5gt_pro_goldentop.v
- c5gt_ddr3.v
Inside the c5gt_pro_goldentop.v file, you will see a 17-bit bus ddr3a_hmc_gnd for the required ground pins in the hard memory controller.
The c5gt_ddr3.v file does not include this bus. These ground pins are automatically added to the pin file during compilation by the Quartus® II software and are not needed in the RTL.
Resolution
The ddr3a_hmc_gnd output bus can be safely removed from the c5gt_pro_goldentop.v file.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
