Knowledge Base Article
Why does the Board Test System fail to run in the Stratix® 10 GX FPGA Development Kit H-Tile Installer Package?
Description
This problem is due to missing files in \examples\board_test_system\jre\, which is necessary for the Java operation environment of Board Test System.
Resolution
To work around this problem, download and unzip jre-patch.zip, then replace these files in \examples\board_test_system\jre.
A Board Test System utility for later versions of the Quartus® Prime Pro Edition Software will be available in the future on the respective device development kit web page.
Additional Information
Board Test System utility version 23.3 on the respective device development kit web page has fixed the issue.
Updated 8 months ago
Version 3.0
