Knowledge Base Article
Why does the Agilex® 5 FPGA EMAC not work with 50MHz Clock Settings?
Description
Due to an issue in the Quartus® Prime Pro Edition Software version 25.1.1, selecting the 50MHz Clock setting for EMAC causes the EMAC to be unable to communicate with the external PHY.
This is due to the clock selection of 50MHz and 250MHz being swapped in the previous version, and was fixed in Quartus® Prime Pro Edition Software version 25.1.1.
In the Quartus® Prime Pro Edition Software version before 25.1.1, when selecting the 50MHz Clock selection, the 250MHz was selected and vice versa.
Resolution
To work around this problem, please only select the 250MHz Clock setting for the EMAC when using Quartus® Prime Pro Edition Software version 25.1.1.
Additional Information
For GMII and RGMII EMAC protocol supporting speeds above 1Gbps, a minimum clock speed required is above 50Mhz.
The clock selection for the EMAC will be removed in future release and a default of 250Mhz will be selected.
This change have been implemented in the Quartus® Prime Pro Edition Software 26.1.
Updated 4 months ago
Version 7.0
