Knowledge Base Article
Why does synthesis of Arria® 10 PCIe* IP generated with VHDL return Error(16045) - ""u_global_buffer_coreclkout" instantiates undefined entity "altera_global""?
Description
Due to a problem with the Quartus® Prime Software version 17.1, the altera_global component entity alias in VDHL is not mapped to the correct VHDL altera_global entity.
Resolution
In the PCIe* top-level VHDL instantiation file, for example, pcie_pcie_a10_hip_0.vhd, comment out these two lines of VHDL code. Then re-run the implementation.
for pcie_a10_hip_0 : pcie_pcie_a10_hip_0_altera_pcie_a10_hip_171_<random string>_cmp
use entity altera_pcie_a10_hip_171.pcie_pcie_a10_hip_0_altera_pcie_a10_hip_171_<same random string>;
This problem is fixed beginning with the Quartus® Prime Software version 17.1.2
Updated 2 months ago
