Knowledge Base Article
Why does Quartus® report errors when HPS SPI signals are routed to FPGA pins for Agilex™ 5 FPGA devices in Quartus® Prime Pro Edition Software version 24.2?
Description
Due to a problem in Quartus® Prime Pro Edition Software version 24.2, when HPS SPI signals are routed to FPGA pins, you may get the Quartus Fitter compilation errors related to the SPI signals.
For Example:
Error (14986): After placing as many components as possible, the following errors remain:
       Error (175001): The Fitter cannot place 1 pin.
           Info (14596): Information about the failing component(s):
               Info (175028): The pin name(s): subsys_hps_agilex_hps_spim0_sclk_out_clk
Resolution
Please use HPS IOs for HPS SPI signals as an alternative.
Additional Information
This problem is fixed in Quartus® Prime Pro Edition Software 25.1.1 version.
Updated 11 months ago
Version 3.0
