Knowledge Base Article
Why does Quartus® IP Parameter not show the PRS interface when using R-tile Multi Channel DMA IP for PCI Express*?
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 22.3 and later,  you might not see the PRS interface even if you check the option "Enable PRS Event" on the IP Editor in the PCI Capabilities tab window, under PCIe* IP Settings.
Resolution
On the IP editor check the option "PF# Enable PRS" on the PCIe Avalon Settings tab widow under PCIe IP Settings.
Updated 11 months ago
Version 3.0
