Knowledge Base Article
Why does my VHDL design fail in hardware when I have a ‘range definition in a loop?
Description
Due to a problem in the Intel® Quartus® Prime Pro Edition Software version 20.3, you may see hardware failures when you have VHDL code in your design that uses a ‘range definition inside a generate loop that is declared inside a generate block, such as the code below. If your design is affected by this problem, your design will likely cause synthesis warnings messages such as the following:
Warning (16788): Net does not have a driver at .vhd(line number)
gen_example: case NUM generate
   when 8 =>
      signal sig : std_logic_vector(1 downto 0);
      begin
         gen_test : for i in sig'range
         generate
            and_gate:and01
            port map ( inp => inp, outp => outp);
         end generate gen_test;
      end;
   end generate gen_example;
Resolution
To work around this problem, download and install the Patch from the appropriate link below.
This problem is fixed starting with the Intel® Quartus® Prime Pro Edition Software version 20.4.
Updated 4 months ago
Version 4.0
