Knowledge Base Article
Why does my V-Series Avalon®-MM DMA for PCIe hang with Txs_waitrequest low?
Description
You will see this behavior if you accidentally issue a DMA request for zero bytes. The request is correctly sent to the host but will be ignored causing the Hard IP for PCI Express to hang waiting on a response from the host.
Resolution
To correct this, ensure that all DMA requests are > 0 bytes.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
