Knowledge Base Article
Why does my Transceiver Reconfiguration Controller Intel® FPGA IP generate Verilog HDL warnings?
Description
Due to a problem in the Quartus® II software version 12.1 and later, you might see the following warnings during Analysis & Synthesis when compiling designs containing the Stratix® V Transceiver Reconfiguration Controller Intel FPGA IP:
Warning (10268): Verilog HDL information at alt_xcvr_reconfig_soc.sv(169): always construct contains both blocking and non-blocking assignments
Warning (10268): Verilog HDL information at alt_xcvr_reconfig_dfe_adapt_tap_sv.sv(302): always construct contains both blocking and non-blocking assignments
Resolution
These warnings are safe to ignore. If you wish to avoid the warnings, edit the files generated by the parameter editor to change the blocking assignments to non-blocking assignments at the indicated line numbers.
For example, the line
mgmt_ram_offset = {RAM_BITS{1\'b0}};
should be changed to
mgmt_ram_offset <= {RAM_BITS{1\'b0}};;
Also, the line
ctrl_wdata = save_ctrl_reg13;
ctrl_wdata <= save_ctrl_reg13;
This problem is fixed in the Quartus II software version 13.0 SP1.
Updated 2 months ago
Version 2.0
