Knowledge Base Article
Why does my PCIe link get stucked in the Detect state for Arria® II and Stratix® IV devices?
Description
Due to a problem in the PCIe Hard IP PMA, the link may get stucked in the Detect.Active state.
This is because the transceiver receiver detect logic not returning a PHYSTATUS pulse on the PIPE interface to the Hard IP core if the low period of two consecutive TxDetectRx is less than 544 ns.
This problem affects Stratix® IV GX, Stratix® IV GT, and Arria® II GX devices.
Resolution
Manually change the Hard IP reset logic to assert the crst and srst signal for at least 1 us.
You can use the following files to view the changes required for both Avalon® streaming and Avalon® memory mapped interfaces to satisfy the requirement above.
- top_rs_hip (.v): Added reset logic can be found on lines 181-211. Put these lines in your <instantiation name>_rs_hip.v file for Avalon streaming interfaces.
- pcie_compiler_0 (.v) : Added reset logic can be found on lines 648-684. Put these lines in your instantiation file for Avalon memory mapped interfaces.
- pcie_compiler_0 (.vhd): Added reset logic can be found on lines 775-810. Put these lines in your instantiation file for Avalon memory mapped interfaces.
Related Articles
Updated 4 months ago
Version 4.0No CommentsBe the first to comment
