Knowledge Base Article
Why does my F-Tile Ethernet Intel® FPGA Hard IP Design Example 40GE-4 variant fail to pass simulation with a System PLL frequency above 805.664062MHz?
Description
Due to a problem in the Intel® Quartus® Prime Pro Edition Software version 21.2, the F-Tile Ethernet Intel® FPGA Hard IP Design Example 40GE-4 variant will fail to pass simulation when using a System PLL with a frequency above 805.664062MHz.
Resolution
To work around this problem, choose a System PLL frequency of 805.664062MHz.
This problem is fixed starting with the Intel® Quartus® Prime Pro Edition Software version 21.3.
Updated 3 months ago
