Knowledge Base Article
Why does my design have timing violations when compiled in the Quartus® II software version 15.0?
Description
Due to a problem in the Quartus® II software version 15.0 Update 1 and Update 2 for Windows, your design may fail timing if it meets the following conditions:
  1. The target device is a Stratix® V or Arria® V GZ
  2. The design implements transceivers
The Quartus® II software version 15.0 Update 1 and Update 2 for Linux is not affected by this problem.
Resolution
To work around this problem, download and install the appropriate patch for your Quartus® II version from the links below. You must install the Quartus® II software version before installing the patch.
This problem is fixed beginning with version 15.1 of the Quartus® Prime software.
    Updated 3 months ago
    Version 2.0
