Knowledge Base Article
Why does my Cyclone V SoC or Arria V SoC design hang on boot or fail SDRAM calibration?
Description
Due to a problem, Cyclone® V SoC and Arria® V SoC devices may encounter the following issues for configurations with clock select (CSEL) pins set to values of  01, 10 or 11:
  1. The HPS hangs during the BootROM stage and is unable to proceed to the Preloader stage.
  2. HPS SDRAM calibration fails during the Preloader process.
Resolution
A patch for the Quartus® II software / SoC EDS versions 13.1 and 14.0 is available to work around this problem,  follow the instructions below.
  1. Download and install the patch from the appropriate link below
  • Connect the CSEL pins [1:0] to pull-down to ground resistors (4.7 kohm to 10 kohm) on the board, CSEL=00. In this CSEL mode the BootROM does not perform PLL configuration and the PLLs are in by-pass state upon power-up or cold reset.
  • Regenerate the Preloader image
    1. Launch embedded command shell
      • On Windows systems, run the batch file:  <SoCEDS installation Folder>\embedded\Embedded_Command_Shell.bat
      • On Linux systems, run the shell script:  <SoCEDS installation Folder>\embedded\embedded_command_shell.sh
    2. In the command shell, change directory to <your_design_path>/software/spl_bsp
    3. Type make clean-all
      • Note: This command removes the Preloader binary image and the uboot-socfpga folder which contains all Preloader source files. If you modified or added files into this folder previously,you should back-up those files and re-apply them after using this patch.
    4. Type make
      • Note: Re-making the Preloader invokes extracting the Preloader source files from SoC EDS installation directory which contains the fix to this issue.
Related Articles
Updated 3 months ago
Version 4.0
