Knowledge Base Article
Why does my Arria 10 design fail after partially reconfiguring a persona?
Description
Due to a problem in the the Quartus® Prime software version 15.1 Update 1 and earlier, your Arria® 10 design may fail after a partial reconfiguration operation.
This problem occurs in the generation of the partial reconfiguration bitstream and may be seen as incorrect functional behavior.
Resolution
To work around this problem, download and install patch 1.01 for the Quartus Prime software version 15.1 Update 1 from the links below. You must install the Quartus Prime software version 15.1 Update 1 before installing the patch.
- Download the version 15.1 Update 1 patch 1.01 for Windows (.exe)
- Download the version 15.1 Update 1 patch 1.01 for Linux (.run)
- Download the Readme for the Quartus Prime software version 15.1 Update 1 patch 1.01 (.txt)
After installing the patch, recompile your design to regenerate the partial reconfiguration bitstreams for your Arria 10 design.
This problem is scheduled to be fixed in a future release of the Quartus Prime software.
Updated 4 months ago
Version 5.0No CommentsBe the first to comment
