Knowledge Base Article
Why does Intel® Quartus® Prime Programmer fail to program an Intel® MAX® 10 device with JTAG Secure mode enabled in a device chain?
Description
You will observe Intel® Quartus® Prime Programmer failure when you have an Intel® MAX® 10 device with JTAG Secure mode enabled in multiple device JTAG chain.
Resolution
To work around this issue, perform Intel® Quartus® Prime Programmer programming separately between the Intel® MAX® 10 device with JTAG Secure mode enabled and the rest of the devices in the JTAG chain.
- When you are programming an Intel® MAX® 10 device with JTAG Secure mode enabled, you need to bypass the rest of the devices in the JTAG chain
- When you are programming the rest of the devices in the JTAG chain then you need to bypass the Intel® MAX® 10 devices with JTAG Secure mode enabled.
This problem is fixed starting with the Intel® Quartus® Prime Software version 21.1.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
