Knowledge Base Article
Why does Etherlink print “Failed to recv H2T header” when using the JTAG-Over-Protocol FPGA IP
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 24.1 and earlier, you may see the Etherlink tool print “Failed to recv H2T header” when using JTAG-Over-Protocol FPGA IP on Agilex™ 7 FPGA and SoC FPGA.
Resolution
To avoid this error, enable the Enable use of TCK-ENA option in the JTAG-Over-Protocol FPGA IP.
Updated 4 months ago
Version 6.0No CommentsBe the first to comment
