Knowledge Base Article
Why does CvP Update fail after accessing the SDM Mailbox IPs in Intel® Stratix® 10 devices?
Description
Due to a known problem in Intel® Quartus® Prime Pro Edition Software version 18.1 Update 1 and later, a Configuration via Protocol (CvP) Update on Intel Stratix® 10 devices could  fail if access to either an Intel Stratix 10 Temperature Sensor  / Intel Stratix 10 Voltage Sensor / Chip ID Intel Stratix 10 FPGA IP core / Stratix 10 Serial Flash Mailbox Client Intel FPGA IP core is performed before the subsequent core configuration.
Resolution
To work around this problem, either hold the SDM IP in reset for at least 1 second after the device enters user mode or remove the instance of the SDM IPs from your design.
See Related KDB
Why does reconfiguration of Intel® Stratix® 10 devices fail with designs containing an instance of any of the SDM Mailbox IPs?
Updated 27 days ago
Version 2.0
