Knowledge Base Article
Why does Configuration via Protocol (CvP) update fail on Intel Agilex® 7 devices when accessing flash through the Mailbox Client Intel® FPGA IP before performing a CvP update?
Description
Due to a problem in the Intel® Quartus® Prime Pro Edition Software version 22.1 and earlier, Configuration via Protocol (CvP) update in Intel Agilex® 7 devices will fail if you access flash through the Mailbox Client Intel® FPGA IP before performing a CvP update.
Resolution
To fix this problem in the Intel® Quartus® Prime Pro Edition Software version 21.4, download and install the following patch:
- Intel® Quartus® Prime Pro Edition Software version 21.4 Patch 0.49 for Linux (.run)
- Intel® Quartus® Prime Pro Edition Software version 21.4 Patch 0.49 for windows (.exe)
- Readme for Intel® Quartus® Prime Pro Edition Software version 21.4 Patch 0.49 (.txt)
If you require a patch for other Intel® Quartus® Prime Pro Edition Software versions, contact Intel® Premier Support.
Updated 8 months ago
Version 3.0No CommentsBe the first to comment
