Knowledge Base Article
Why does configuration of my Intel Agilex® 7 device fail with a SmartVID or PMBus error when using the Intel® Quartus® Prime Pro Edition Software version 22.1?
Description
Due to a problem in the Intel® Quartus® Prime Pro Edition Software version 22.1, you might see a configuration failure of your Intel Agilex® 7 device with a SmartVID or PMBus error if your design meets the following conditions at the same time:
  • Using AS configuration mode
  • Using an internal oscillator as the configuration clock
  • Using PMBus host mode
  • Using Programming File Generator version 22.1 to generate bitstream from sof file
You might see an increased SmartVID or PMBus frequency when the issue happens. If you use the TCL command according to AN 936: Executing SDM Commands via JTAG Interface to read the error message, you might see a similar error message as follow:
% sdm_config_status
 Version: 0x00160100
 MSEL[2:0]: 001 (AS (Fast POR))
 Configuration pin signals:
  nSTATUS: 1
  nCONFIG: 1
  CONF_DONE      : 0
  INIT_DONE      : 0
  CvP_DONE       : 0
  SEU_ERROR      : 0
  HPS_WARMRESET  : 0
  HPS_COLDRESET  : 0
 MSEL[2:0] Table:
  3'b000 AvST x32
  3'b101 AvST x16
  3'b110 AvST x8
  3'b001 AS (Fast POR)
  3'b011 AS (Normal POR)
  3'b111 JTAG only
 State: 0xf002c808
 Error location: 0x00001800
 Error detail: 0x00000001
 Configuration fail!
  Major code: 0xF002
  Fail to access QSPI or PMBus voltage regulator (VID).
  Minor code: 0xC808
Unknown minor code, please refer to latest Mailbox Client IP User Guide for detail.
Resolution
To fix this problem, use the Programming File Generator from the Intel® Quartus® Prime Pro Edition Software version 22.2, and download and install the following patch:
Updated 2 months ago
Version 2.0
