Knowledge Base Article
Why does configuration intermittently fail when using a JIC file generated with Quartus® Prime Pro Edition version 24.2 and later on Agilex™ 7 FPGA devices, resulting in Major Error Code 0x0000F004 and Minor Error Code 0x0000D006?
Description
You may encounter the following errors during configuration using a JIC file generated with Quartus® Prime Pro Edition version 24.2 and later, targeting Agilex™ 7 FPGA devices with F-tile and/or R-tile:
  • Major Error code: 0x0000F004;
  • Minor Error Code: 0x0000D006;
This issue affects configuration behavior on Agilex™ 7 FPGA devices with F-tile and/or R-tile.
Resolution
To  work around this issue:
  • Power cycle the FPGA.
  • Note: Triggering nCONFIG will not resolve the issue.
Patches are also available to fix this problem for the following Quartus® Prime Pro version:
  • 24.2: Quartus Prime Pro Edition Design Software v24.2 patch 0.59fw
  • 25.1: Quartus Prime Pro Edition Design Software v25.1 patch 0.25fw
This problem is fixed starting from Quartus® Prime Pro Edition version 25.1.1 and later.
Updated 8 months ago
Version 4.0
