Knowledge Base Article
Why does compilation failure happen when adding assignments of TX equalization to the F-Tile FGT channel for Intel Agilex® 7 FPGA?
Description
Due to a problem in the Intel® Quartus® Prime Pro Edition software version 22.2 or 22.3, a compilation error may occur during Logic Generation with some valid assignments of TX equalization combinations on the F-Tile FGT channel.
Error example:
Error(21842): Support logic cannot be generated because IP components used in the design have conflicting settings
Error(21843): Conflict 0 ----------------------------------------------------------------
Error(21843): Rule: gdra_ip758fluxtop::ux3_txeq_main_tap_relationship_rule @ gdr.z1577a.u_ux_quad_2.flux_top
Error(21843):     {(gdr.z1577a.u_ux_quad_2.flux_top.ux3_txeq_main_tap -> IP_INST[0].hw_ip_top|dut|eth_f_0|hip_inst|per_xcvr[0].x_bb_f_ux|x_bb_f_ux_tx.txeq_main_tap)+(gdr.z1577a.u_ux_quad_2.flux_top.ux3_txeq_post_tap_1 -> IP_INST[0].hw_ip_top|dut|eth_f_0|hip_inst|per_xcvr[0].x_bb_f_ux|x_bb_f_ux_tx.txeq_post_tap_1)+(gdr.z1577a.u_ux_quad_2.flux_top.ux3_txeq_pre_tap_1 -> IP_INST[0].hw_ip_top|dut|eth_f_0|hip_inst|per_xcvr[0].x_bb_f_ux|x_bb_f_ux_tx.txeq_pre_tap_1)+gdr.z1577a.u_ux_quad_2.flux_top.ux3_txeq_pre_tap_2<=32'd47} || gdr.z1577a.u_ux_quad_2.flux_top.ux3_powerdown_mode == TRUE
Error(21843): Rule: gdra_ip758fluxtop::ux3_txeq_pre_tap_1_range_rule @ gdr.z1577a.u_ux_quad_2.flux_top
Error(21843):     gdr.z1577a.u_ux_quad_2.flux_top.ux3_powerdown_mode == FALSE || (gdr.z1577a.u_ux_quad_2.flux_top.ux3_txeq_pre_tap_1 -> IP_INST[0].hw_ip_top|dut|eth_f_0|hip_inst|per_xcvr[0].x_bb_f_ux|x_bb_f_ux_tx.txeq_pre_tap_1) == 0
Error(21843): Input variables:
Error(21843):     user.bb_f_ux_tx[0] -> IP_INST[0].hw_ip_top|dut|eth_f_0|hip_inst|per_xcvr[0].x_bb_f_ux|x_bb_f_ux_tx
Error(21843):         is_used == TRUE
Error(21843):         location == UX11
Error(21843):         txeq_main_tap == 40
Error(21843):         txeq_post_tap_1 == 13
Error(21843):         txeq_pre_tap_1 == 1
Error: Design cannot be programmed onto available F-Tiles because given location constraints are conflicting, or because the design requires more resources compared to what is available on current device
Error: Quartus Prime Logic Generation Tool was unsuccessful. 14 errors, 0 warnings
Error: Peak virtual memory: 12882 megabytes
Error: Processing ended: Fri Sep 30 11:22:52 2022
Error: Elapsed time: 00:01:49
Error: System process ID: 25039
Resolution
To work around this problem in the Intel® Quartus® Prime Pro Edition Software version 22.2 or 22.3, follow the steps below:
1. Check the TX equalization setting in F-Tile TX Equalizer Tool
2. Write equalization value to lane register offset 0x47830
This problem has been fixed in the Intel® Quartus® Prime Pro Edition Software version 23.1.
Updated 11 months ago
Version 3.0
