Knowledge Base Article
Why does Agilex® 7 FPGA M-Series fail to launch U-Boot proper after a Warm reset in release 25.3.1 and later?
Description
Due to corruption in the device tree on the Warm reset flow in the Agilex® 7 FPGA M-Series device, the resolution of the u-boot,spl-boot-order = &mmc node fails at the re-entry of the U-Boot SPL, resulting in the loading of the U-Boot proper failing. The error observed is the following:
Hit any key to stop autoboot: 0
SOCFPGA_AGILEX7M # reset -w
resetting ...
Do warm reset now...
U-Boot SPL 2025.10 (Dec 11 2025 - 10:49:42 +0000)
Reset state: Warm (Triggered by MPU 0)
MPU 1350000 kHz
L4 Main 400000 kHz
L4 sys free 100000 kHz
L4 MP 200000 kHz
L4 SP 100000 kHz
SDMMC 50000 kHz
HBM: SDRAM init in progress ...
HBM: Calibration success
HBM: Warning: DRAM size from device tree (2048 MiB)
mismatch with hardware (4096 MiB).
HBM: 2048 MiB
HBM: size check success
HBM: firewall init success
HBM init success
board_boot_order: no valid element spl-boot-order list
SPL: failed to boot from all boot devices
ERROR ### Please RESET the board
This problem is observed regardless of the method used to apply the Warm reset, and this is present in release 25.3.1 and later.
Resolution
There is no workaround for this problem. This will be fixed in a future release.
Updated 4 months ago
