Knowledge Base Article
Why does Agilex® 7 FPGA M-Series fail to be reconfigured after applying a software cold reset from U-Boot proper in Quartus® Prime Pro release 26.1?
Description
Due to an incorrect implementation of the cold reset flow in U-Boot proper, in Agilex® 7 FPGA M-Series in release 26.1, the FPGA/JTAG is not kept in a clean idle state, resulting in the JTAG reconfiguration rejection. This causes the following error observed when you try to reconfigure the device after the cold reset:
SOCFPGA_AGILEX7M # reset
resetting ...
Mailbox: Issuing mailbox cmd REBOOT_HPS
rolando@rolando3-linux-lab:~/tasks/testbin$ quartus_pgm -c 1 -m jtag -o "p;ghrd.hps.rbf@2"
Info: *******************************************************************
Info: Running Quartus Prime Programmer
Info: Version 26.1.0 Build 110 03/26/2026 SC Pro Edition
Info: Copyright (C) 2026 Altera Corporation. All rights reserved.
Info: Your use of Altera Corporation's design tools, logic functions
Info: and other software and tools, and any partner logic
Info: functions, and any output files from any of the foregoing
Info: (including device programming or simulation files), and any
Info: associated documentation or information are expressly subject
Info: to the terms and conditions of the Altera Program License
Info: Subscription Agreement, the Altera Quartus Prime License Agreement,
Info: the Altera IP License Agreement, or other applicable license
Info: agreement, including, without limitation, that your use is for
Info: the sole purpose of programming logic devices manufactured by
Info: Altera and sold by Altera or its authorized distributors. Please
Info: refer to the Altera Software License Subscription Agreements
Info: on the Quartus Prime software download page.
Info: Processing started: Tue Jun 30 18:42:30 2026
Info: System process ID: 93542
Info: Command: quartus_pgm -c 1 -m jtag -o p;ghrd.hps.rbf@2
Info (213046): Using programming cable "Intel Agilex M-Series Development Kit - HBM2e Edition on AN04WVAW035PS.an.altera.com [1-12]"
Info (213011): Using programming file ghrd.hps.rbf with checksum 0xA66FE7E5 for device AGMF039R47AC@2
Info (209060): Started Programmer operation at Tue Jun 30 18:42:32 2026
Info (18942): Configuring device index 2
Error (18952): Error status: Device does not accept configuration request
Error (18939): Unexpected error in JTAG server: JTAG chain broken
Error (18952): Error status: Detected error when rescan jtag chain
Error (209012): Operation failed
Info (209061): Ended Programmer operation at Tue Jun 30 18:42:43 2026
Error: Quartus Prime Programmer was unsuccessful. 4 errors, 0 warnings
Error: Peak virtual memory: 1235 megabytes
Error: Processing ended: Tue Jun 30 18:42:43 2026
Error: Elapsed time: 00:00:13
Error: System process ID: 93542
Resolution
To work around this problem, you can disable the watchdog timer before issuing the cold reset. This can be done using the wdt stop command from the U-Boot shell as shown next:
SOCFPGA_AGILEX7M # wdt list
watchdog@ffd00200 (designware_wdt)
SOCFPGA_AGILEX7M # wdt dev watchdog@ffd00200
SOCFPGA_AGILEX7M # wdt stop
Note: You need to build your U-Boot to support the wdt command by setting CONFIG_CMD_WDT=y in your build configuration.
You can also apply the cold reset from Linux, in which the error is not observed. For this, you can use the reboot command from the Linux shell.
This problem will be fixed in a future release.
Updated 3 months ago
Version 2.0
