Knowledge Base Article
Why does Agilex® 5 FPGA and Agilex® FPGA 3 HVIO PLL fail to lock after reconfiguration?
Description
HVIO PLL reconfiguration may require word-addressed register offsets for Agilex® 5 FPGA and Agilex® 3 FPGA devices. The HVIO PLL reconfiguration registers for Agilex 5 and Agilex 3 devices are documented using byte offsets, but the Avalon® Memory‑Mapped (Avalon‑MM) interface expects word-addressed offsets. Using the documented byte offsets directly on the address bus can cause incorrect register access, which prevents the PLL from recovering after it loses lock during reconfiguration.
Resolution
Apply the following workaround to ensure correct HVIO PLL reconfiguration:
  1. Use word-addressed offsets when accessing HVIO PLL registers through the Avalon-MM interface.
  2. Convert documented byte offsets to word offsets by dividing by 4 before driving the address bus.
  3. Update the register address mapping in your design accordingly.
Example:
localparam [8:0] ENABLE_RW_ADDR        = 9'h10 >> 2; // 0x04
localparam [8:0] ENABLE_RECAL_ADDR     = 9'h48 >> 2; // 0x12
localparam [8:0] CLK_GATING_ADDR       = 9'h54 >> 2; // 0x15
localparam [8:0] CLEAR_STATUS_ADDR     = 9'h58 >> 2; // 0x16
localparam [8:0] C0_ADDR               = 9'h5C >> 2; // 0x17
localparam [8:0] C1_ADDR               = 9'h60 >> 2; // 0x18
localparam [8:0] RESET_ADDR            = 9'h80 >> 2; // 0x20
localparam [8:0] RECAL_ADDR            = 9'h88 >> 2; // 0x22
Updated 3 months ago
Version 2.0
