Knowledge Base Article
Why does Agilex™ 7 SoC FPGA fail to access DDR space when HPS EMIF is enabled with Half Rate Converter (HRC) On and Quarter Rate?
Description
Due to a problem with u-boot-spl(u-boot-socfpga-v2022.01) for Agilex™ 7 SoC FPGA, you may not be able to access all HPS DDR space when HPS EMIF is enabled with Half Rate Converter (HRC) On and Quarter Rate. For example, if HPS EMIF is a 2GB configuration, HPS can only access the first half of 2GB, and the second half of 2GB is just an alias for the first half.
Resolution
To work around this problem, you need to change the source code in u-boot-socfpga/drivers/ddr/altera/sdram_agilex.c(81) from
update_value |= (hmc_readl(plat, CTRLCFG3) & 0x4);
To
update_value |= 0x4;
Additional Information
This problem has been fixed in with u-boot-spl(u-boot-socfpga-v2023.01).
Updated 1 month ago
