Knowledge Base Article
Why does adding a DDR4 IP to an Agilex® 9 Power and Thermal Analyzer (PTA) project in Quartus® Prime 26.1.1 and earlier result in an error?
Description
When adding a DDR4 IP to an Agilex® 9 Power and Thermal Analyzer (PTA) project in Quartus® Prime 26.1.1 and earlier, some DDR4 IP properties may be populated with invalid values. As a result, the project may generate errors and fail to compile or analyze correctly.
Resolution
This issue has been fixed in Quartus® Prime 26.3. As a workaround for earlier versions, manually update the affected DDR4 IP properties to valid values before proceeding with project compilation or analysis.
Published 17 hours ago
Version 1.0No CommentsBe the first to comment
