Knowledge Base Article
Why does a stack dump occur during an OpenCL™ kernel compile if the loop count exceeds the number of channels allocated?
Description
A stack dump may occur during an OpenCL™ compile if a loop contains a write to an indexed channel and the loop count exceeds the number of channels allocated. See the example code below.
channel unsigned char my_channel[16] __attribute__((depth(1024)));
char data[32];
for (unsigned char i = 0; i < 32; i ) {
write_channel_intel(my_channel[i], data[i]);
Resolution
Be sure that the loop count never exceeds the number of channels allocated.
#define num_channels 32
channel unsigned char my_channel[num_channels] __attribute__((depth(1024)));
char data[num_channels];
for (unsigned char i = 0; i < num_channels; i ) {
This problem is fixed beginning with version 19.1 of the Intel® FPGA SDK for OpenCL™ compiler.
