Knowledge Base Article
Why does a dynamic reconfiguration operation fail when using Intel® Stratix 10 fPLL FPGA IP configured in Core mode?
Description
Due to a problem in Intel® Quartus® Prime Pro Edition Software version 19.3 and earlier, when targetting an Intel Stratix® 10 L-tile or H-tile FPGA device you will see the Dynamic Reconfiguration tab in the IP editor when configuring the Intel Stratix 10 fPLL FPGA IP in Core mode.
However, the dynamic reconfiguration feature is not supported for the Intel Stratix 10 fPLL FPGA IP when configured in Core mode.
Resolution
To work around this problem, if the dynamic reconfiguration feature is required by your design do not configure the Intel® Stratix® 10 fPLL FPGA IP in Core mode if applicable.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
