Knowledge Base Article
Why do the Intel® Arria® 10 10GBASE-R Design Example User Guide and simulation test bench file show an incorrect Tx/Rx SC FIFO offset address ?
Description
Due to a problem with the Intel® Arria® 10 10GBASE-R design example, the register map offset address for RX SC FIFO is 9400h and TX SC FIFO is 9600h.
However, in the "Low Latency Ethernet 10G MAC Intel Arria 10 FPGA IP Design Example User Guide" (ug-20016), the offset address for RX SC FIFO is D400h and TX SC FIFO is D600h.
Resolution
The 10GBASE-R design example's register map offset address for TX SC FIFO and RX SC FIFO will be amended to match with register map offset address in the ug-20016 design example user guide.
This problem will be fixed in a future version of the Intel® Quartus® Prime Software.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
