Knowledge Base Article
Why do the F2H (FPGA2HPS) subordinate signals showing "zzzzz"?
Description
Due to a problem with the QuestaSim* SE on Quartus® Prime Pro Edition Software version 25.1.1, when using the BFM testbench on F2H (FPGA2HPS) AXI4 and ACE-lite bridge, subordinate signals may appeared to have “zzz” or “ZZ” in the readings.
Example of signal waveform in QuestaSim with “zzz” or “ZZ”:
Impact:
In QuestaSim, a "zzz" or "ZZ" signal usually indicates a high-impedance state (floating) or uninitialized value in the VHDL simulation, often appearing in the Wave window when signals are not being driven or have not received a value.
Resolution
Possible workarounds:
- Add Missing Pull-up/Pull-down resistors: If the signal is intended to be high or low when not driven, ensure a pull-up or pull-down resistor is properly modeled.
- Fix Unconnected Port: Ensure signal in the waveform is connected correctly in the testbench.
- Optimization Issues: Design optimization can cause signals to appear missing or in an incorrect state. Try adding +acc to the vsim command to improve visibility, e.g. vsim -voptargs=+acc <top_module>
This problem is scheduled to be fixed in a future release of the Quartus® Prime Pro Edition Software.
Updated 6 months ago
