Knowledge Base Article
Why do the 10G and 25G example design SOF files generated for the E-tile Ethernet IP for Agilex® 7 FPGAs with target development kit "Agilex® 7 FPGA F-series Development Kit (Production 1 P-Tiles & E-tile)" fail to program?
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 25.1, you may see failures when programming SOF files generated with the 10G and 25G E-Tile Ethernet Hard IP design examples for Agilex® 7 FPGA devices.
This issue applies to the E-Tile Ethernet Hard IP for Agilex® 7 FPGA devices and is limited to the 10G and 25G Example Designs
Resolution
To workaround this problem, modify the PWRMGT_LINEAR_FORMAT_N setting to "-13" in the hardware test design QSF file located in <design_example_dir>/hardware_test_design.
The problem has been fixed starting with Quartus® Prime Pro Edition software version 25.1.1.
Updated 3 months ago
Version 6.0No CommentsBe the first to comment
