Knowledge Base Article
Why do Stratix V C1 and I1 speed grade devices show incorrect voltage in the Device settings dialog box?
Description
Due to a reporting issue in the Quartus® II software version 11.1SP2, the Device settings dialog box shows incorrect core voltage for Stratix® V C1 and I1 speed grade devices. The Device settings dialog box shows 0.85 V but the correct voltage is actually 0.9 V.
Resolution
For the actual voltage setting, open the Quartus II Settings dialog box by selecting Settings from the Assignments menu. In the category listing, expand the Operating Settings and Conditions category and select Voltage. The VCC Voltage for Stratix V C1 and I1 speed grade devices is correctly shown as 0.9 V.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
