Knowledge Base Article
Why do I see zero value from chip_id[63..0] when reading the unique chip ID in Arria 10 devices?
Description
During the initial production phase, some Arria® 10 devices did not go through the wafer sort process. Thus the unique chip ID was not programmed for these build lot devices and see you will see a zero value from chip_id[63..0] when reading from the Arria 10 Unique Chip ID IP.
Resolution
Even though these Arria 10 device are from a blind build lot, all the units are tested at final package level testing, thus they are all fully functional units.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
